Correct timing at idle and at full throttle no load is essential. TDC at idle, and with a light look for the last timing mark for full advance. Adjusting the carb idle screw for best idle, and low speed 450rpm. is usually good. They can make some sniffling noises. If it is 12v it needs a ballast resistor in the circuit between the ignition switch and the coil. The coil should be attached with the Plus terminal to the distributor if it is Positive ground, and - to the distributor if it is - ground. Jim
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
