Re: TD340 Backhoe and 3121 Backhoe attachment
Posted by eddietude on September 13, 2011 at 00:20:44 from (98.148.33.84):
In Reply to: Re: TD340 Backhoe and 3121 Backhoe attachment posted by Jim Becker on September 12, 2011 at 16:03:16:
Hey Jim,
thanks for the reply. From what I could tell, the 3121 was mounted on several wheeled tractors that had weight similar, or even less than, my td340.
BUT, the 3121 looks really big compared to the TD340. I'm not concerned about the fabrication, I have access to everything I'd need to do that.
Do you have a 3140? Or know someone who has the pictures of one? those would be a huge help.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
