Posted by GriffNC on September 11, 2011 at 06:56:29 from (71.49.53.241):
In Reply to: C Farmall posted by Craig Tenhoff on September 11, 2011 at 06:25:15:
Sounds like fuel supply to me .Check filter screen both at bottom of tank and screen into carb ( if it has one ) You need a good flow of fuel by gravity to carb. If you have an inline filter get rid of it , it will not let enough fuel flow to carb. Check float in carb . One trick I do in unscrew the plug at the bottom of the carb. Let the gas run out and see how much of a flow I have there .I have taken a fine wire and run up into carb and lifted the float to shut off fuel flow .JI ggle that several times to make sure there is no small piece of trash there .
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
