You are correct (if you looked at it at all, the wrong way hits the bolts.) On assembly it is possible to get the engine off enough to bend the hub of the clutch. If it is bent, the disk drags. Fixing requires it to be removed and straightened so it has less than .005" runout. If the splines on the Clutch shaft are worn, or the disk hub to shaft fit is tight, it will drag. Adjustment will not help either. If the fingers are withing .005" in height when the clutch pedal is released, they are OK. Best of luck, Jim
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
