Posted by farmallhal on September 07, 2011 at 08:55:31 from (71.49.71.106):
In Reply to: Farmall H with hi lo posted by jjsfarm on September 07, 2011 at 07:54:27:
I have both a M and H with the Heisler 9 speeds and think they are a great item on those model tractors. As Bob M. says they are nothing like a TA but do provide 4 additional gears I find very useful. The four additional gears are for speed ranges between the standard 4th and 5th. When I obtained my M up in Iowa I was told they came out to provide a 7 MPH speed which was required for a rotary hoe to work properly. My uncle had one on a M when he farmed corn in Iowa back in the late 1940's and 1950's and found the Hi 4th provided about a 12 MPH road gear with considerable torque for a heavy load of picked corn. I believe the Heisler on M tractors is fairly common but no so on Farmall H's. After liking my M Heisler so much I went on a hunt for a H with one and it was not easy and took several years before I found a nice one last summer. There is also the same type of modification produced by M&W with a cable control mechanism which looks like a choke cable on a lawn mower. I believe the Heisler is a much cleaner and nicer installation which seems appropriate with the tractor. I would certainly recommend you give the tractor some serious consideration as you won't find many H's with one from my experience, Hal. P.S. Since the Heisler speeds up the PTO and the belly pump it is not recommended to use either when in the higher speed ranges as those components will be over running their design limits. My tractors have a belly pump disconnect which can be engaged when using the higher speed ranges.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
