Posted by Bob M on September 07, 2011 at 08:25:27 from (69.207.87.100):
In Reply to: Farmall H with hi lo posted by jjsfarm on September 07, 2011 at 07:54:27:
The Heisler 9 Speed increases ground speed in 1st thru 4th gears by about 40%. It also increases PTO speed and belly pump RPM by the same percent when engaged. It however does not affect 5th gear. Hence the "9 speed" designation.
The Heisler is not a true predecessor to the Torque Amplifier. A T/A DECREASES travel speed when engaged. Also a T/A can be shifted while under load. The Heisler however can only be shifted in/out while the tractor is stopped.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
