To use the two way system (assumes a belly pump, not a pump in front of the distributor on the engine) it is necessary to pull the lower control rod that attaches to a longish lever with a spare hole on it, to the rear and hold it there. The other rod should now provide up and down control. THe rod can stay out all the time because the other valve is open centered, and will dump pressure into the reservoir when in the centered position. If pulling the lower rod with the control rod centered causes the engine to losd down, somthing is not connected correctly. See caseih.com search for parts put Farmall in the box. Scroll down to SMD THen select hydraulics. Jim
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
