Re: adjust touch controls
Posted by realolman on August 29, 2011 at 17:15:02 from (108.22.70.94):
In Reply to: adjust touch controls posted by farmall400 on August 29, 2011 at 04:37:43:
farmall400 said: (quoted from post at 04:37:43 08/29/11) Sounds like you might have double acting cylinders and your valves
set for single acting or single acting on double setting.Take the rt
hood panel off and look at valve ther is a pin pointing to a d or s
on each valve section it is crossways on a shaft with flats so you
can put a wrench on it and switch back and forth. we had to do it
every year when we put the picker on and off. If that is set to match
your cylinders you have a detent problem inside the valve. hope
that helps. Scottz
it will raise the tractor off the ground with down pressure.... does that indicate anything?
it seems like it's the hydraulic pressure itself doing it.
This post was edited by realolman at 17:23:08 08/29/11.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
