Posted by David Lampman on August 23, 2011 at 19:31:51 from (69.54.29.239):
In Reply to: Rust in tank posted by kopeck on August 21, 2011 at 18:21:34:
K, I just went through my tank after it sat for 15 years. When I first looked in it I was sure I would have to line it. It looked to me to be very rusty. But I tried that on an old Suzuki tank with disastrous results. Besides, there is a baffle in your tank (as you know) that I think would not allow you to get a good "flow" of the lining goo. What I did was to soak the tank with a gallon of lacquer thinner. (Don't forget to plug the hole in the bottom first :-))I swished it around every so often for 3 days. When I dumped it out I couldn't believe the crud that came out. It turns out that my "rust" (it really looked just like rust) was shellac from 50 years of gas evaporating. Then I used a commercial steam cleaner (not just a pressure washer, you need the heat) set at 300 degrees and sprayed the s**t out of it through both holes. When I look inside it now it looks like it's brand new. Hope this helps Dave
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
