Where are you located? Get ALL the orbitor(sp) power steering parts from a "03 modelIH, "05 model JD or newer SP combine. You will need all the parts including the steering axel mounted cylider/with mounting brackets, a manifold with 6 0r 8 ports located usually under operators platforn and steering wheel that is attatched to a motor(can"t think of proper name for this part), prioty(sp?) valve, and mayby a few other parts. As in all power steering applications this would best with a dedicated pump from a combine or a pickup. Before you you partsfrom donar combine take plenty of pictures esp. of how how p.s. cylinder mounts to combine steering axel. I should have a picture of all the parts that I will try to post if you need them. E=mail is open if you have any questions, By the way when you clean that manifold all the ports should be labeled. Enjoy the project, I would think you should be abel to do this for ABOUT $500. Armand
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
