Another possible alternative is stick a Charlynn PS kit in the steering shaft ahead of the gear box. A friend did this to his MM G and a Case 900 - they both now steer nice and easy. No reason it can't also work on an SW6.
Downside will be cost. You need the torque generator itself, a hydraulic manifold block, shaft U-joint, flow divider (priority valve) and several interconnecting hoses. Figure on $800 - $1,000 unless you can score these parts at a boneyard.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
