Posted by El Toro on July 30, 2011 at 09:59:44 from (108.15.86.54):
In Reply to: Farmall H: no spark posted by Ofischill on July 30, 2011 at 07:44:07:
If you have a distributor you should check to see if you're getting battery voltage to the coil. Use a volt meter and with the ignition switch in the on position and the points open you should have voltage on both small terminals on the coil. If you have voltage rub the points with some 320 wet or dry until shiny then see if the engine will start. If you have a mag make sure your grounding switch isn't grounding out the points. Clean them too. Hal
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
