Once you get the tank off probably a trip to the radiator shop to soak in their dunk tank. Then there is a process to epoxy the inside of the tank (requires an acid wash first I think). Then primer and new paint the outside of the tank. Then the tractor will look kinda silly until you paint the whole thing. If the tank was that bad, the sediment bowl, fuel line and carburator will likely be gunked up too. Carburator cleaner may do it but I've had best luck cleaning the cast parts in a blasting cabinet. Figure on new gaskets all around. Remember there is a small brass screen in the float bowl inlet which is often clogged up.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
