Farmall 100 Hyd pump fixed but not fixed errrrrrrrrrrr!
Posted by chad from michigan on July 22, 2011 at 16:40:04 from (67.142.164.24):
Well I got the right seal today and I installed it. Got the pump back on the hard lines the bypass block put fluid in it and I can not get the pump to pump. I pulled the lines back off and poured hyd fluid down to the pump to try to prime it but that didn't work. The system was prety much empty so am I expereincing no prime to the pump or air? what do I need to do? please anyone? I see a plug on the pump I figured I could prime it there but as usual the aluminum pump wont let go of the steel pipe plug.
Thanks
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
