Re: Super H - want to hear it run wont start!
Posted by rhtx55 on July 21, 2011 at 16:35:33 from (207.119.63.83):
In Reply to: Super H - want to hear it run wont start! posted by Farmall Bob09 on July 20, 2011 at 18:48:24:
One other possibility is the distributor is out of time. Pull no1 plug, and double check the ignition timing, point gap, coil output, condenser.
Use autolite plugs. It surely must be something simple.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
