Right now i have the tires and rims off the front end because they were flat and weather checked..when I get ahold of a set of tires I will try pull starting it. I do have spark at each cylinder. I have the wires hooked up right on the cap and to the plugs. However I will recheck that the rotor points to number one plug tower on the tdc of compression stroke at cylinder one. Thanks for all of the input. I will get back to you guys and let you know what I found. Appreciate the help!
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
