If the plugs are dry you're not getting fuel, plain and simple.
There's no magic involved. Either the gas isn't getting to the engine because there's no suction, or the gas isn't getting to the engine because something is plugged up in the carburetor.
I took my Super H carb apart half a dozen times before I got it right. There are nooks and crannies in there that are not obvious. On mine the float was apparently jamming against the side of the bowl, but there was no evidence.
One thing to check: Did you open the high speed and low speed needles on the carb after you reinstalled them? I think the low speed is 1-1/2 turns and the high speed is 4-5 turns to start with. If those are tightened down, no gas will flow.
Also use the choke when cranking, but be careful you could flood the engine.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
