Posted by Owen Aaland on July 17, 2011 at 20:21:16 from (216.47.33.237):
In Reply to: pepper, again posted by blunted on July 17, 2011 at 17:49:46:
Your earlier post indicated that you have had the problem since an engine rebuild. I am going to assume that means you replaced the sleeves. If you did, what are your sleeve to deck height measurements? Sleeve height above should generally be .000 to .005 inches above the deck. More important is no more than about .002 between any two adjacent sleeves. If those specifications are off you likely never will get a head gasket to seal.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
