Posted by CNKS on July 17, 2011 at 18:29:30 from (216.144.104.128):
In Reply to: pepper, again posted by blunted on July 17, 2011 at 17:49:46:
The newest spec is 85 ft lbs. Don't go any higher, I have 3 of those engines and they don't leak. You said earlier you have an A and the gasket is for a 123? Tractors with a factory 123--not an overbore kit like you have -- have water pumps, that is why your gasket says 123. Regardless of your displacement, if your engine does not have a water pump, you need a C113 gasket. The water holes in it are larger, the C123 gasket has smaller holes. That may or may not be your problem, but it may be, particularly if your radiator is pressurized -- but if it is, it is not original, many have been changed. The earlier comments about being sure the head and block are flat still apply.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
