Posted by Fixerupper on July 16, 2011 at 08:37:30 from (207.199.205.239):
In Reply to: 1086 Problem posted by SENEBRFRMER on July 15, 2011 at 17:52:47:
Cab relay. Flick the key switch on and off a few times to see it that will make it kick in and get things charged. Otherwise, turn the key on and tap on the relay. That might spring it to life too. Jim
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
