Re: Is A W6 Rear End Housing Same As A M
Posted by jaybird2 on July 06, 2011 at 19:40:56 from (63.152.130.53):
In Reply to: Is A W6 Rear End Housing Same As A M posted by Benny2011Mn on July 03, 2011 at 14:25:38:
They are not the same. Quite different animals from the engine on back.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
