That tractor has a seperate pump mounted piggy back on main pump, and relief valve for the hitch and if the hitch is not being used the flow from hitch pump joins the flow from main pump behind the aux valve mounting. There fore , when you pull aux valve and it makes tractor labor that only tells you the main pump is working and the unloading valve to hitch if most likely ok also. So, that brings you to a weak hitch pump, leaking hitch relief valve which is under the cover under seat or blown internal o-rings in draft control valves or cyl. Could possibly by action control valve sticking but I would have to feel your lever to tell you that. If your hitch will go up and down with no load and follow the positiion control lever all right ( MEANING IT WILL NOT JUST GOT ALL THE WAY TO TOP OR BOTTOM) I would think your linkages are ok.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
