Again, not being familiar with the particular layout of the system, mainly the plumbing, If there is a location in the lines where you can disconnect the line between the pump outlet and any of the steering components, if you have or can find a needle valve to install directly from the pump, and squeeze it down a little at a time to see if it builds pressure, that would tell you what the pump is capable of. Since the relief is built into the outlet of the pump, you will not hurt anything and it will tell you if the pump will supply oil to build pressure. If you are dumping the oil into a bucket from the needle valve, if the pump is working, it should flow up to the point of shutting the valve off completely and should reach system pressure before it's shut completely off. Of course, we had equipment available to do these things and I do not know what you have handy. An external relief valve in place of the needle valve would also do, but you are less likely to have anything like that. At about 3gpm, a 1/4" needle valve rated at 2500psi should do.
pete may know a simpler way to do it, or if there is a place to break into the system like that.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
