The basic hydraulic system on a 1954 Super H is a ONE-way system. All you will have is the hydraulic "block" under the gas tank, and one lever.
There are two ports on a casting that protrudes from the rear of the hydraulic block on the left side. Those are your pressure/return ports. BOTH ports provide pressure when you pull the lever back, and BOTH ports allow the fluid to return when you push the lever ahead.
Two-way hydraulics are an add-on. You need a separate "open center" two-way valve. To hook it up, you connect one of the one-way pressure/return ports to the IN on the valve. You connect the OUT from the valve to the 1" drain hole located on the back of the hydraulic block on the right side. Mount the valve somewhere convenient. Run hoses from the "work" ports on the valve to the rear of the tractor and install quick-connects.
To run the two-way valve, you first lock the lever on the hydraulic block in the "back" position. Now oil flows through the two-way valve, which you can use to control a two-way cylinder.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
