Posted by 36F30 on June 21, 2011 at 19:04:45 from (71.214.218.237):
In Reply to: f 30 cables posted by rusty faubion on June 20, 2011 at 20:55:52:
Rusty your original brake cable guides had to be removed to mount the corn picker and usually were not put back on. If you want an original set they are the same for the 20 and 30 and should be easy to find.
The cornpicker cable guides are long galvanized pieces that pin on and are really hard to find Here's a pic (in the wrong location) of a set on a F20.
And here is a scan from my 22B picker manual showing the heat shield and cable guide parts. Part #4
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
