RTR, those numbers are for corn plates. All the plates are 24 cell (that's what the "24" after the dash means. If you use these plates your planter has to have it's sprocket settings geared for 24 cells. Many old planters used 16 cell plates so take note. Refer to your owner's manual for the correct sprocket settings.
I do not think you have a real "good buy" at those prices, as plastic plates are plentiful. But if they are new then it's your money.
You do NOT need all those plate numbers. I am listing the plates in descending order of cell sizes. (There is no rhymm or reason to the numbers as they are not in descending order).
C13 large round seed C54 (very seldom needed) C1X medium round C15 (very seldom needed) C2X small round C25 (very seldom needed) C3 very small round
C8 large flat seeds C11 med large flat C7 med flat C65 (seldom needed) C6 small med flat C10 (seldom needed) C9 small flat C19 very small flat
Do you have any plates that came with that planter? If so, are they 16 or 24 cell? (Count the cells around the perimeter).
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
