I'm going to key in on your statement "it often starts runing very rough" and maybe take a different slant on your problem. Does your engine really run rough or is it simply surging? If it is rough, you need to make sure the fuel and ignition systems are in order before you get into the governor. Maybe you need a tune-up. If the ignition is in shape and the caruretor is delivering enough fuel, the next thing to check is the linkage between the governor and the carb.
With the engine off, unpin the forward end of the rod that connects the governor arm to the carburetor. Push the control lever forward. Pull the (now disconnected) rod back so the carb is wide open. The pin in the linkage should be able to slide back in without moving the other parts. If it doesn't, turn the yoke on the front end of the rod to the longest adjustment that will let the pin slide in. Make sure that link moves freely with no binding.
Only AFTER doing all this, remove, clean and adjust the bumper spring as already mentioned.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
