Centerline of the tractor to inside of right rear tire should be 27 1/2 inches. If plowing deeper than 8 inches add 1 inch to measurement. Do not use swaybars or anything to keep the plow from moving right or left. It will stay where it belongs if the plow is adjusted correctly. When its in the ground it should set level right to left, and front to back. If the cut of the furrow is to wide or to narrow, there is an adjustment on most plows to point it to narrower or wider cut.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
