The full 16" cut of the first share is measured from the landslide to the tip of the share farthest away from the landslide. This tip should be very near the furrow when the right wheel is in the furrow plowing straight. Stopping with the plow in the ground, and digging a little will let you find it. The vertical position of that tip is also important as this makes the depth constant on each pass. Adjust the wheel spacing so the first share cuts full width. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
