Re: IH 80 snowblower
Posted by 495man on May 30, 2011 at 14:34:55 from (69.60.67.215):
In Reply to: IH 80 snowblower posted by kennell on May 29, 2011 at 17:58:02:
Definitely an IH 80.
I have a 70.
The 80 has the upper auger option and the brace on top of the gearbox, the 70 only has the gear box bolted from the bottom.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
