Get into the mowable grass and start mowing. While going straight, shut off the engine and let it stop. Take the PTO out of gear, then carefully look at the grass being cut. Starting in front of the tractor, and continuing under the deck till you get to the blades. This should indicate what is happening as it cuts. Smashed down grass can respond to a second reverse direction cut. Short blades are a real possibility. Be careful to check all clearances if longer blades are used. Do not compromise with the wrong blades. Use OEM or replacement blades made for it. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
