Posted by Janicholson on May 23, 2011 at 20:50:35 from (67.72.98.45):
In Reply to: more cub problems! posted by farmallboy15 on May 23, 2011 at 16:27:23:
I will add to the possible list that there could be junk in the seat (where the needle closes off the incoming fuel. If the strainer in the fuel inlet fitting is clean, it should flow. There is a need to check that fitting screen at the carb, it is often an issue. Jim
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
