Posted by truckinthumbtack on May 23, 2011 at 19:42:08 from (204.116.206.247):
Started to clean up the push rods and the "socket end" (adjuster end) on some is severly pitted from laying in the bottom of the "basket of parts" it came to me in. Is there a way to polish the socket or will the pitting not hurt anything? I was thinking of takeing an auto push rod and chucking it in a drill and putting some valve grinding compound on it. Have any of you tried something like this? Or is new the only way to go?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
