Posted by K-Mo on May 21, 2011 at 14:09:48 from (67.55.164.37):
In Reply to: cub lo boy 185 posted by jason the red on May 21, 2011 at 13:22:45:
If you mean an external spring to hold the PTO engaged, the answer is no. The PTO clutch is cam activated and snaps into engaged position. There is an external spring on the pull rod that I would call an anti-rattle spring to keep the pull rod from rattling around. As you pull the PTO rod up, you should feel the tension increase slightly, then snap into engaged position. If this does not happen, the problem is in the clutch. If you need more detailed info, send an email to me.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
