Posted by gene bender on April 28, 2011 at 05:42:32 from (207.177.56.53):
In Reply to: Re: fuse posted by TractormanNC on April 28, 2011 at 04:48:19:
They call the bulbs 35 watts so amps times volts is what i based the fuse on. With the system in shape the ammeter will show pretty good discharge without engine running anyhow isnt the fuse supposed to be 20 amp
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
