Posted by John A. on April 23, 2011 at 12:35:33 from (76.1.122.180):
In Reply to: smta lp serial # posted by jmducks1 on April 23, 2011 at 07:33:13:
jmducks1, The quintessential SMTA-LP has a longwise tank(as you described) with a mono-valve assembly at the 11:00 position at the rear of the tank (if you are sitting in the seat). This tank set up probably came from Lubbock or San Angelo Texas. Though there were 4 other tank companies scattered through out the Deep South. Pics would be nice to see. If you would like to visit about your tractor or the SMTA-LP series Hollar at me 512-577-3837. I will be glad to tell you all I know about it. Hope this helps! Later, John A.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
