Posted by Bob M on April 23, 2011 at 09:49:07 from (67.240.171.41):
In Reply to: smta lp serial # posted by jmducks1 on April 23, 2011 at 07:33:13:
I presume #65692DGS is the tractor serial #? If yes, then per Guy Fay's "IHC Tractor Data Book":
D = 5,000 ft altitude G = high drum cotton picker attachment S = T/A with provision for live PTO.
However the book also lists "C" for LPG fuel and "N" for LPG fuel above 2,500 ft altitude. Would seem then your tractor should have both C and N in the suffix, if it came factory-equipped to burn LPG and for high altitude operation.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
