Posted by AG in IN on April 18, 2011 at 16:32:32 from (67.236.85.111):
In Reply to: Tisco Carb Kit posted by J.L. Every on April 18, 2011 at 06:32:19:
The last Tisco tune-up kit I bought for an IH distributor on an M I had to bend/twist the points quite a bit to get them to align squarely. Might have been just the kit I bought, I don't know. I've have had better luck with Tisco kits for D-R distributors.
The last A&I kit I bought the rotor was junk. You could slide the contact piece around about 1/4 inch.
The last "genuine" CIH ignition parts I bought the cap woudn't even come close to fitting properly. They must have changed suppliers or something about a year ago.
All imported condensers seem to be of questionable quality. Some work fine, some make your points look like you welded on them after 5 hours, some just quit. I try to reuse my old condensers if the points look fairly decent for the hours that are on them.
Lately I've been buying NAPA/Echlin ignition parts. Pricey, but they fit and hold up well. I have also had good luck with Standard and Blue Point ignition parts in the past, too.
Years ago, nearby TSC or QFF stores stocked "Standardized" ignition parts in a bubble pack. The other had "Sorensen" ignition parts. Both were good bang for your buck.
The holes in some of the aftermarket bowl gaskets are usually a bit off. Make sure you use good packing for the main fuel adjustment screw if it isn't in the kit. When you get the carb apart, make sure you shake your float to be sure it doesn't have a hole in it. Check for throttle shaft bushing wear too.
Some folks curse the rubber-tipped needle seats, but I think they're in the CIH kits, too. The rubber-tipped ones stick once in a while and the old style steel ones can seep.
Always check dimensions of the main nozzle before swapping it out if it's in the kit. I can't speak for Tisco's kits, but A&I's nozzles are sometimes wrong. Compare all shafts, butterflies, etc., to your old ones.
Don't toss any old parts until you are happy with the way your tractor runs with the new parts in the carb.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
