The only thing that could have caused that is if the new thermostat stuck closed. It didn't feel or smell hot. I did pull about a pint of oil on the side of the road, checking for antifreeze, I had gloves on but did manage to splash some,it was hot but didn't burn me. I did touch the side I of the block. Again warm but not any hotter than normal. Radiator didn't overflow. Only lost a enough to wet the block from the head gasket.
I ran fine for about the 45 minutes it took to plant and then made the 2 mile trip home in 4th wide open throttle.
The only difference was the radiator cap was loose after the incident.
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli
... [Read Article]
Latest Ad:
1945 Farmall wide body gas with pto and front plow. Runs good but needs new points.
[More Ads]
