Cam, Crank, valve timing will not be affected by removing the pump and gear - when all reassembled you must set the distributor timing. This I think is easiest to do by marking top dead center before removing the distributor, use timing mark on crank pulley - when it is TDC the rotor under distributor cap will point to number one cylinder plug wire when cap is installed on distributor. Sometimes you will find that parts are already marked; the cap may have something to show #1 spark plug wire and the metal distributor case may have a small grove scratched or cut to show where the rotor points for #1. Mark these positions for an easy way to re-time the distributor. When you are ready to reassemble be sure the crank pulley is aligned with the TDC point, then install distributor with rotor pointing to the mark you made on the case of the distributor. Most important I think have a repair manual; Always best not to rely on memory and my typing. With my IH 300U I continue to have hydraulic issues, it seems that I can never get everything working exactly right?
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
