Posted by farmallhal on March 29, 2011 at 07:24:53 from (76.4.170.93):
In Reply to: frame weights posted by oldiron29 on March 29, 2011 at 04:03:28:
The part no's. for the front frame weights for the Farmall 200 and 230 are 361158R1 (L/H) and 361159R1 (R/H) and they each weight 86 pounds. These same weights will fit on a C and Super C tractor. There are only two weights (one L/H and on R/H) used on the C, SC, 200 and 230 models. The Farmall and International 240 tractors can utilize three on the front and are quite difficult to find and they will not fit on the tractors you mention in your thread as they are quite different. Hope this helps, Hal.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
