If the ring gear is bad, that requires that the tractor be split in half to access the flywheel at the rear of the engine.
The clutch and pressure plate needs to be removed, then the flywheel.
The ring gear wraps around the flywheel, and is a shrink fit. The old gear needs to be cut off with an acetylene torch. The new gear is heated and dropped on to the flywheel.
While you're in there, you may need to have the flywheel resurfaced. You may need to replace the clutch and pressure plate. You may need to replace the IPTO drive gear. You may need to replace some seals.
It sounds like you may want to have this service performed by a mechanic. Splitting a tractor is a pretty advanced task.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
