Posted by rustred on March 10, 2011 at 09:07:53 from (74.200.18.155):
In Reply to: Farmall A compression posted by Randy McClena on March 10, 2011 at 08:47:44:
cleaned head and valves? did you remove valves if did , must be replaced in same guide it came out of. when looking at valves need to know what to look for, like the seat and so on. turned engine over by hand? is this with the crank so you can get a steady revolution? if so then it should blow air out of plug hole with finger over hole. proper check is to use a guage if you want a good reading. did you adjust valves properly? manifold off dont matter. the most probable cause would be valve not seating, or not adjusted or not rotating engine fast enough during check.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
