Posted by DeltaRed on March 04, 2011 at 19:39:48 from (97.124.219.62):
In Reply to: ih 140 plow posted by gaston ruiz on March 04, 2011 at 18:25:52:
I used to pull 3x14s with my 706.it was a good match.3rd or 4th gear.hay ground would take every bit of 3rd gear.Stay with a 3 bottom.A 140 is a lot of plow for a 706.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
