Hi John, I assume your 826 has the German D-358 Diesel engine. I have never worked on the 6 cyl version, only the 3 and 4 cyl versions but the parts are the same except for number of cylinders.
First question, did you loosen the 3 cap screws on the injection pump drive gear? If you loosened these screws, I hope you marked the exact location, if not you will have to do a static timing on the injection pump.
If you did not loosen the cap screws then the injection pump is probably 180 degrees out of time. The pump only turns at 1/2 the engine rpm so to keep the pump in time, if the drive shaft is turned then the pump drive shaft has to be turned 2 revs to keep the timing. So to correct this problem you will have to remove the pump and turn the drive shaft 1 rev and re-install the pump.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
