Posted by rustyfarmall on March 01, 2011 at 14:19:01 from (209.152.78.140):
In Reply to: M rear end posted by mkirsch on March 01, 2011 at 13:09:05:
That is what happens when the bearing fails. A ball falls out and then gets trapped between the bull gear and the housing, and since there isn't any room to spare, the housing cracks. My 1940 M has a patch consisting of a length of sheet metal and some heavy gasket material. The patch is held in place with about a dozen or so small machine screws and lock washers. The screws thread into holes that were drilled and tapped. The patch is kind of ugly, but it works, and it is definitely a part of the tractors history, so it will just stay that way.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
