Posted by Owen Aaland on February 22, 2011 at 19:22:44 from (65.174.247.39):
In Reply to: 706 Starter posted by Rtkman-706 on February 22, 2011 at 12:00:07:
Diesel fuel getting inside the starter usually does not make them not spin at all. It can make them turn slower and have less power. The symptoms you describe are usually caused by the battery cable stud being eroded so far that it no longer makes good contact with the disk inside. The way to check it is to see if the starter motor will turn if you short across the two large terminals. If it spins then the problem is the solenoid. If it still does not spin the most likely cause is worn out brushes.
If the solenoid stud has not been turned before it is a simple matter to remove the battery cable and feed wire, loosen the retaining nut about 1/4", push the stud in and turn it 1/2 turn. It will only fit two ways so be sure to turn it a half turn. Tighten the retaining nut and reinstall the wire and you're done.
If the brushes are worn to the point where they no longer are making good contact with the cummutator bars on the armature, you will need to have it resurfaced. Don't bother with undercutting the mica on the commutator. It needs to be done with generators but the brushes in starters are hard enough that they will wear the mica down along with the copper so that you will not get arcing like would occur in generators.
You will most likely have to replace the drive end bushing. The other two are often OK to reuse. Check for wear on the shift lever. There is a brake washer between the drive and the center housing that will need to be replaced. You will need a new solenoid plunger boot. If it is a real early starter it may have 1/2" plugs for the shift lever pivot pin but most likely there are 5/8". The larger plugs are 1 3/16".
If you are not going to replace the oil wicks they should at least be removed and soaked in oil. Do not use grease in the bushings, just be sure the wicks are oil soaked. I see a lot of "rebuilt" starters that are put together with grease, often missing the oil wicks, and those are the ones that have the bushings worn out.
If you are going to replace the starter drive use the one for the D310 engine instead of your D282. The main difference between the two starters is the drive. The D282 uses a drive with five rollers for a clutch. The D310 uses a drive with a sprag clutch like the other large diesels. If you want to go top of the line you can use a ratchet clutch drive but that is really overkill for a D282.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
