Not familiar with the location of the particular seal, but will assume it's the typical stamped seal casing with the rubber lips in the middle.
When they're stuck hard, I usually suggest heat and penetrants, almost like busting a stuck bolt free. Heat both, the seal and the surrounding metal. As it cools, shoot your favorite (PBBlaster . . . ) onto the seam while it's still hot but cool enough that it doesn't sizzle away. As it cools it will draw the stuff in. Might take several cycles of that -- the heating and cooling will mechanically break up any rust holding it, and the penetrant will do what it does.
As for the mechanical part of pulling . . . I dont know how much you've buggered up what you have. There's the standard tool made for pulling, kind of like a double-ended narrow hammer claw. If that isn't gonna work in your situation, the most common alternative is to drive a couple of screws into the face of the shell of the seal and use a prybar to pull from under the screwhead -- it works well but works better if you've at least applied a penetrant, and even better if you put the heat to it, as well.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
