Posted by Allan from PA on February 08, 2011 at 06:51:06 from (76.125.180.44):
In Reply to: OT: Heat posted by willie1 on February 07, 2011 at 07:32:50:
I have a small Dayton electric unit heater that hangs from the ceiling. My garage is 20x25 with 9ft ceiling and insulated as best I could. I keep the garage at 50 degrees when not using it and turn it up when I need to. Didn't think I wanted a heat source with an open flame because I thought I would probably blow myself up eventually. Not really economical to leave on higher temps but works for me, keeps things from freezing and the wife's car is in the garage so it makes points there. Allan.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
