Re: Farmall 230 quits after running fine for 30 min
Posted by DeltaRed on February 07, 2011 at 20:10:28 from (97.124.219.62):
In Reply to: Farmall 230 quits after running fine for 30 min posted by John McFadden on February 07, 2011 at 19:51:30:
bad coil
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
